CMF_techNot
» CMF MemberHi Everyone,
Having trouble with the K11, 1.0lt, 16valve automatic. Its a 1993! Had a look at some threads here and got some great info but no joy yet!
The plugs are sparking, but no fuel. Put new fuel filter in. Put a pump in. (old pump works off battery, Doh)
Swapped a relay from near ECU into fuel pump relay spot still no luck. Put a meter on wires at pump and no power when cranking. No power at fuel pump relay on crank either?
When changing the pump I poured some juice into throttle body and fired her up no problem until juice ran out.
can somebody teach me how to check earths at ECU? or all earths, or maybe immoboliser???? confused!
