Hi all, apols for the long post....i have a K11, year 2001, three door,no a/c,no sunroof.
After raining I have wet passenger and drivers floors.( Not coolant as the water is colourless and clean)
I have removed scuttle cover and sealed the green window holders and the plastic scuttle receiver plugs.I have sealed the rubber seal where the wires run from the upper part of both doors into the main bodywork. I can see the air intake in the scuttle and didn't notice any water dripping into it when I used a water hose to mimic heavy rain.
Bottom of A pillars are dry and no water sitting in the cills.Also freed up base of the mud flaps so now drain away quickly.
Is it possible for water to transfer from the passenger side floor to the drivers side floor or does it mean I have two water entry points,one for eack floorwell...
I'm snookered at the moment...anyone got any suggestions...
