k11 turbo kit
CMF_Martinb21
Evening guys :)
Right having a change about and selling the t2 turbo and ancillaries
It's originally from a fiesta rs turbo and in very good condition internally with no play and no smoky smoky :)
The manifold is a frankspeed manifold with a custom ford t2 flange on
I have the fiesta rs turbo modded to fit and have cut the downpipe so that it could be joined on by the next owner to there exhaust system so have left enough on there
It comes with the oil feed banjo and banjo bolt specific for this turbo and this has a 4-AN fitment so your oil feed hose you order has to have this to fit
The stock return is on there with a rubber joiner, you will need the fitting from eBay to connect the return back up as mines staying on the sump
This turbo is capable of 160bhp at around 10 psi with fueling and map.
Same setup really as polly p or noddie
This could be run at a very low boost setup without intercooler with not much left to get!
Worldwide shipping available
Paypal only or cash if picking up
£260 + postage ovno
And don't worry I'm not out the turboing just yet, just looking at other options
Can text or call
07825159531 (u.k)
[email protected]
