kennierobo
Buy & Sell Member
I know this has sort of been covered before but more detail is needed as im having pinking problems after new dizzy instalation, the other thread reads as follows..............
Well the timing marks on the crank pulley read from left to right when standing facing the pulley are -5 -- 0 -- 5 -- 10 -- 15 -- 20. So TBC on cylinder 1 will be the second mark from the left, usually coloured yellow, however this has usually come off on older cars.
Standard ignition timing is 15deg + or - 2deg. So with your strobe connected up the pointer should be hovering above the second to last notch on the pulley. Setting it by hand isn't that hard since the engine isn't under load, so the chances of you doing damage are extremely slim. You should be able to set this with the TPS connector unplugged, as explained in the Haynes Manual. Allow the engine to reach temperature and check the timing again. Failing that, just post up again and we'll do our best to help you through it
NOW what i need to know is ............is the second to last notch on the pully starting from left or from right as you look at it.
as i remember on other cars you have marks either side of top dead centre so for a micra 998cc is the timing before or after tdc before been left side and after been right as you look at it .....................dont mean to confuse you all.:blush: :blush:
