It's been quite a while that I connected my laptop to the K11 and I think I forgot about 90% of my knowledge of Datascan somewhere between my ears. For the record: I made this video
So in 2015 I have re-flowed the MAF. That doesn't mean it can't be bamboozled again, but the video above shows how I re-flowed it. I was cautious not to leave flux behind as you can see, so corrosion is unlikely...
When the car is warm it wants to stall (and does so) when idle. The first thing I thought about was the MAF and so I grabbed my laptop with Datascan and my Consult cable to see if my gut feeling was correct. "Unfortunately" the 'air flow sensor' stayed clean (no DTC's and no erratic behavior). But it came to my attention the O2 sensor was all over the place. To me it is a bit of a 'chicken or the egg' story (is something wrong in the engine and then the O2 sensor goes haywire or is the O2 sensor going crazy which makes the engine run bad...). Maybe one of you guys can help me out.
When driving I remember that during engine braking it showed me it was giving a RICH mix to the engine. If I recall correctly it should show LEAN mix. All the time the O2 sensor acted very nervous.
In the Datascan software you can select 'Base idle adjustment'. When I click this the engine drops drastically in revs (below 350) and eventually (after a few seconds) stops running. Should I tamper with the set screw to get the revs right now or should I try to fix my erratic O2 sensor first? I don't know what to do. What is the correct behavior of my O2 sensor? Could this cause my revs to drop when I select 'Base idle adjustment'?
Shoot!
Shoot!
