K11 stalls after driving for 10min....
CMF_rowstar
Surely not the TB this time....
I can drive for about 5km around town before it starts to fuel cut and stall completely.
...and then it won't start until 1hr later. then it will do the same thing...5km then stall.
Once it stalls completely and i pull to the side of the road, the starter motor is working but just won't kick over. And also the battery then becomes intermittent - dash warning lights not even working. But all is fine if i just wait and hour or 2.
have a feeling it has to do with something heating up due to having to leave it turned off for a while before it starts again.
I have soldered the TB a few times now and fixed it each time no probs every few months. This is kind of the same symptoms how it cuts out, but even when the TB was at it's worst it would still kick over and start straight away.
any ideas? cheers guys
CMF_sikK11
I would say crank angle sensor if micras have them. Seems when it gets hot it stops working. Had to replace the one on our WRX last week for same reason. Find the Crank angle sensor if cg;s have them and hose it down when it stops. Then see if it starts. Or just check for spark. If there is no spark then thats your problem. When it cools the sensor works and will work until its hot again.
CMF_asdame
maybe the idle speed is also set too low.
normally idles at 1300rpm when cold then the IAV closes when warmed up to drop the idle down to 700rpm.
if the IAV works fine and the idle screw is set too low, it'll idle fine when cold above 700rpm but once warmed and the IAV closes and idle drops below the optimum 700rpm therefore engine cannot sustain momentum & stalls
try warm up the engine and then turn the allen head idle screw at back of TB anti-clockwise to raise the idle up to 700rpm
CMF_rowstar
it is idling fine, cold is at 1200rpm, then warm is 800rpm.
at traffic lights etc idle is fine, but as i said i can feel fuel cut while cruising and then sure enough next time i stop at lights it will idle kinda ok but splutters and stalls as i go to take off. this is usually 10 min into driving.
CMF_rowstar
had the RACV look at it...
checked spark plugs, fuel pump etc....they said the crank angle sensor is actually working, but the distributor doesn't have a great spark or is heating up and then cutting out.
So i got a bottle of cold water and slowly poured it over the dizzy metal casing that attaches to the side of the head....and sure enough that did allow it to start again for a short while.
so....off to the 'parts section' for a secondhand dizzy.
hopefully, fingers crossed, this is the solution.
