K11 RPM tacho
Hi guys, whilst reading the Maxi Micra thread it was mentioned that the clockset was replaced with a set containing an RPM gauge (where the water temp normally is on the left). I have a 1.0l '96 model: is it a straight swap for a set of dials with the RPM gauge ones or do they need re-wiring et cetera? I think the ones I am looking to buy are from a '94 1.3l model. If these can be fitted as a direct swap, is £50 a good price?
Any help much appreciated:)
my 96 1.0 L model needed the little link wire added near the ecu ELA (described in seb,s tacho thread) and £50 is a little high tbh :)
Many thanks once again Frank:) Would you perchance have any idea where I can locate this Seb tacho thread as using "seb" and "tacho" in the search doesn't show anything? My appologies if this seems like a real school boy error on my part; I only registered on this site a couple of days ago.
