k11 rear drum axle.
davey1991
If its not scrubbing, its not low enough.
I have a rear disk axle i'm willing to swap for a drum axle with some money.
Or willing to buy one if its cheap enough.
on the ramp wouldnt be to hard. the nuts/bolts are usualy siezed normaly adding to the cost,more so if the arms and bushes get traumatized (mine survived)
on the floor like i done didit is suicide,,,,,,,,dont do it
you want the cables with the axle or buy seperate as the drum ones are difrent
and knock through the remaining bolt in the arm bushes, to save cost
Thanks for the info r-reg-sr, i need to get my hands on the rear disc axle, if you know anyone who has 1 lying around let me know, thanks again
let me clear this up
this site is pack'd with the right vit and minerals, so i just passed info to you given to me by pollyp, frank , evofrenzy, and others
also the disc axle and drum axle havent much diffrunce(according to members feedback,so is it worth it,,,,, you should decide
I kept it incase I wanted to go back to drums, as there is not much difference. Shoes and drums are in good condition. I have dry stored it in my garage since I took it off. It was from a Japanese import, not much rust on it
Just make me an offer
