K11 rear brake shoes
CMF_sva86
Do you remove the hub and the bearing like on the pic,or you can take them out without dismounting the bearing.
And did you remove the springs first,because i did not managed to take
spring No 3 out.I removed the 5 things that you said removed the other
two springs 2/4 but without,but even after that i could not take the shoe out.
CMF_frank2
its a lot easier with the hub off (just 1 very tight nut to remove eh)
and with the 2 x #5,s off you should be able to lift the whole assy off so that it all hangs on the cable
CMF_sva86
OK.
Thank for the help.
I will try again tomorrow.I tough that it will be quite easy if
the hub is removed,but i did not managed to unscrew the hub nut as well.
