K11 (prefacelift) Throttle body refurbishment
Hi
Is there a company which sells or does K11 (preface lift) Throttle body refurbishment?
My garage diagnosed via plug in codes, that my rough running and low idling, point to the mass air flow sensor, I am going to do the re-soldering trick again, to see if that works, but does anyone refurbish them?
What are the new aftermarket ones like?
the new ones, are worse then the old ones. Try to get a used one cheap, as long as they are still available.
got a new Distributor, wich after ~2years an ~10kkm (6000miles) ist leaking Oil! YES, not the ignition coil is damaged, but its leaking oil through the shaft from the attachment to the camshaft.
Write your reply...
