only pre-face 1.0 k11 have the smaller diff splines mate, my k10 long shaft fitted fine, and i think the short shaft is the same length tooI have an early pre f/l k10
So if I took the shafts from a k11
Would it fit my gearbox, then use the k11 hubs I've got?
dunno neil, i can measure the 1.0 and 1.3 hub splines if you want to double check ?
what dia are your disc,s ?
i meant the k10 ones tbh neil (to make a comparison)Havnt got discs or calipers yet mate
they were off the car mate (scrapyard)Il take a look
What year k10 were your shafts from?
half a spline aint it mateMine has a totally different spline to yours frank
the pre-face k10 ones must be different then eh neil, the bare shaft might be the same tho ?
here,s the 2 different types (22mm and 24.5mm)
