Can anybody advice me on what performance mod can i do on a 1995 micra K11 with a cg10 engine doesn't have to be very expensive mods. thks in advance guys
Janspeed manifold but do not replace the 2nd CAT or you'll fail your MOT
Custom Back box - this can be anything but I've used a Power Flow one that looked great.
Alloys - Get a set of 15" - I wouldn't recommend anything larger has you'll need arch work at it'll slow the car down (I have a set of 15" for sale if your intrested).
Lowering Springs - It's not that hard to replace the spring if you have a set of compressors. Normal drop is 35mm
K&N 57i Induction Kit plus relocation/extra air ducting
Front Top strut brace - Also if you have an older k11 i might not have a anti-roll bar, if this is the case get one off a scrapped car fitted (watch for brush wear)
If you start getting CAMS and ECU's it'll start costing money. All the Mod's I've recommended above can be done for less than £1k or even less if you get the parts 2nd hand.
