K11 Panhard
CMF_Litttleb
Hi!
I'm from Hungary, and thinking of lowering my K11. There are lots of lowering spring kits available, but no adjustable panhard rods.
My friend adviced to cut (shorten) the factory rod.
But how much to cut down? Is it ok to fit the lowering springs than put the car on the ground without the panhard rod and measure the distance between the rod mounting points? Or is there a better method?
Thanks in advance
mik
Hey man,
there's a adjustable panhard from whiteline. You can purchase it from UK if you can't find one in your country.
mik
CMF_frank2
its only 6 or 8mm littleb, but the stock p/rod is pretty flimsy and i would be wary of cutting it :O
i wanted to make an ally one but mine,s rusted on solid, so i shaved a bit off, of the offside wheelspacer instead
frank
