K11 Panhard Rod bush sizes.
Afternoon all,
Currently undertaking a rear axle replacement on my 2000 K11. Ive sourced arms as ALL the bolts were seized and bushes had to be burnt out to remove them.
I had however overlooked the possibility that my panhard rod bolt may well be seized on the axle end and require the same treatment.
I refuse to pay £25+ for a single poly bush. If I can find the rough dimensions of the bush I can source something else that will do the job. If my judgement is right I think I could get away with using a Polo front lower arm front bush.
Or does anyone know of another bush that will do the job for me? I need the car this weekend so its vital something is sourced before then.
Cheers, Sam.
