k11 or k12
CMF_shalon
whats up ppl, i'm in a situation and here how it goes
i'm just about to turbo my 1.3 k11 which i cant wait to do, the someone offered me a trade with a 12c k12 for my k11. the deal is i have to give him my k11 and i in retured will be getting a k12 from japan. i know the k12 makes more power the the k11 but wat i dont know is which of the two engines are more stronger when it comes to dailly driving, handleing and fuel eco
CMF_sikK11
the k12 is ugly i would stick with the k11. they loook better unless i have missed a model and thinkin of the wrong one. But the k11 has our hearts and i would turbo that one.
CMF_shalon
sikK11 WROTE:
"the k12 is ugly i would stick with the k11. they loook better unless i have missed a model and thinkin of the wrong one. But the k11 has our hearts and i would turbo that one.
lol
its a bit ugly for real but cant help thinking about the thunder i can creat from the k12 when i turbo him. i will like to know does the k11 and k12 uses same brake pads
CMF_nz_aj
K12 has multi coil, variable cam phasing & more room under the bonnet.
I have a sneaking suspicion that the block is very similar between CG & CR. Look at the bore & stroke figures for the various capacities.
CG10DE, CG13DE, CR10DE, CR12DE bore 70.1mm
CG10DE, CR10DE stroke 63.0mm
CGA3DE, CR14DE stroke 82.8mm
2 door 12c was available in Japan, 2002-2004.
http://catalogue.carview.co.jp/spec/NISSAN/MARCH/2002/22920/
CMF_frank2
nz_aj WROTE:
"K12 has multi coil, variable cam phasing & more room under the bonnet.<BR>
<BR>
I have a sneaking suspicion that the block is very similar between CG & CR. Look at the bore & stroke figures for the various capacities.<BR>
CG10DE, CG13DE, CR10DE, CR12DE bore 70.1mm<BR>
CG10DE, CR10DE stroke 63.0mm<BR>
CGA3DE, CR14DE stroke 82.8mm<BR>
<BR>
2 door 12c was available in Japan, 2002-2004.<BR>
<A href="http://catalogue.carview.co.jp/spec/NISSAN/MARCH/2002/22920/" title="http://catalogue.carview.co.jp/spec/NISSAN/MARCH/2002/22920/" target="_blank">http://catalogue.carview.co.jp/spec/NISSAN/MARCH/2002/22920/</A>
the CR blocks do look very similar nz_aj, bellhousing bolt spacing look the same to me, but its an ally sump and the alternator, P/S pump etc brackets are integral/cast in.
some pics on post # 143
http://www.micra.org.uk/showthread.php?t=22225&page=3
frank
