I've had this N reg for a few months and it's been fine. Sadly I caused the problem when it overheated (obviously not fully antifreezed) shortly after starting in the morning (no problems starting then). I left it to cool down/de-frost but simply won't start; the engine turns over easily but there's no spark.
I have a Haynes workshop manual so I was able to check the ECCS codes. I'm sure that initially there was an "overheat" but I reset them and tried to start and that's when it reported the "ignition system" fault. At that point it was taken to the local garage (who are good) but even with their better diagnostic software it still only says "ignition system" failure which isn't that helpful; and, of course, they are fairly busy and haven't that much time to spend...they have said that they've looked at the obvious - of course.
I'm wondering whether the actual ECCS could be damaged and I'm tempted just to see what I can get from the second hand parts people.
Any suggestions welcome.
