k11 micra
hi i have a 2001 nisan micra k11 coil pack model i was driving the car a few days ago and it was holding back then cut out and wont start the fuel pump wont work unless you put a permanent live to it but still wont start because it has no spark any ideas :p:p
right i have seen something like this being spoken about very recently indeed try the search function if not someone will help or point u in the right direction mate
and welcome
I would check the fuel pump relay and fuse first of all:)
Edit: hmm, no spark either, power to the ecu? (the ecu controls the fuel pump relay and the spark)
hi mate checked the fuel pump fuse it was ok where is the relay and if its not that do you think the ecu could be at fault also the car was holding back before it cut out and would not start again
