Hi chaps
The engine on my Mrs car developed a rather quiet rattle somewhere around the top LHS (near side) of the engine last weekend. I stopped the engine at the time checked things over and couldn't see anything to miss, it had seemed to have come from around water pump/ timing chain or top end around the tappets. Nothing seemed amiss the belts were in good order etc... but i told her to listen out of it and to keep her music turned down in case it came back. Two days later I get a call just as she got to work telling me the sounds come back but with a vengeance, it's really loud this time and the car engine was shaking enough the make the gear stick move! She was forced to drive it home but it wasn't there when she started it but started to faintly come in as she neared home (3miles).
I checked the car over in the morning and found the dip stick dry!! Now i'll admit i assumed the worst but still thought it prudent to top the oil up as the oil light does work and it hadn't come on. so I topped up the oil, started the car and after about a minute the sound disappeared completely, i assumed that this was for the better and there was a chance the timing chain was splash fed and topping up the oil had quietend things down. So as i've been doing major work to my Honda over the last few days and with work and being pressed for time i advised her to run it and to keep an ear out for the rattle. She took the car for a short run again today and the noise came back again after about a mile not as loud as before but then she only drove 2 miles, then on her return journey it came back but louder.
So can anyone point me in the right direction as to what to check as i'm not convinced her running the car low on oil is defiantly related to the rattle.
Again in short: Nissan Micra P reg 998cc with 62thousand miles
Previously very well serviced
No history of any engine problems
The car isn't ragged around and has no mods
Top end rattle around the timing chain, as fast as a tappet
engine recently run low on oil but the working oil light didn't come on.
Please help
Rob
Please help
Rob
