Hi,
just signed up to this forum as I am in the process of a cg13 swap into my Austin mini
Basically I have a cg13 and g/b and shafts, the outer side of the shaft has 22 splines.
BUT mini outer cv's have 19 splines, I read that the 1.0 pre 98 micra shafts had 19 just like the mini
and the shafts fit straight into mini outer cv's which is brilliant, but my question is, if I get hold of a
set of shafts from a pre 98 1.0 will they fit into the 1.3 inner cv's? if not will the 1.0 inner cv's fit into the 1.3 gearbox? if so then I can get the 1.0 shafts and all ill need to do is get them shortened, welded n sleeved.
Thanks,
Jonathan
Thanks,
Jonathan
