K11 Hubs
superls
K10 Tuner
hi, ive read an this forum lots of times that the K11 hub is supposed to fit on the K10, lots of people say that it should but i am yet to find any hard evidance that it will or anyone that has actually done it.
so what i need to know asap is, will the K11 hub fit the K10?
or will the N14 hub for example fit the K10? or K11?
cheers superls
The K11 hub will fit the K10, I've sort of done it, my K11 March ran K10 hubs as standard, I put K11 hubs on it so its obviously going to work the other way, all I had to do was put new track rod ends on as they're longer on a K11.
Quickdraw did it.
He has it on his 2 ltr k10.. ill see if i can find the page were i was reading it. Think it was on the almera owners club!
But it might have been on here, it was a while ago though!
Edit: found this on a quick search on here.
http://www.micra.org.uk/showthread.php?t=791&highlight=quickdraw
Has some information but i can actually find the one with pictures though!
It also mentions it in Dbull's thread, there is apparently a guide but im not a member so dont know this to be true or not!
http://www.micra.org.uk/showthread.php?t=1588&highlight=brake+upgrade
I've had k11 hubs and brakes on my car for ages, they will bolt straight up, but like sonic said you need longer tie rod ends and the flexi pipe won't fit up like stock. I thought loads of you guys had already done this?
how many times!?!?!? yes they do fit! i've seen it done
i must have covered this at least 5 times this month alone, and i posted a guide in the DIY section
seeing as we have established that the K11 hubs do fit. (cheers and sorry speedle) will the N14 hubs fit to make the mod ever so much easier, then all the parts are off of the same vehicle???
superls
