K11 ECU to GA16 Help
This is not strictly K11 help but it does include a K11 ECU.
I've recently been having problems with my GA16 powered K10, I have many reasons to believe it is immobilised by NATS.
So earlier on I bought a Pre-NATS K11 ECU after having been told you can run a GA16 on one. But I'm also aware that some wires need to be swapped and cut out etc. But whilst trying to find the changes that need to be done, of course my GA loom is different to the K11 loom and I don't posses the knowledge to translate what is being changed on the K11 loom and identify the same on the GA loom.
So I was wondering if there was anyone out there that already knows how this is done OR could look at each loom/pinout, compare them and tell me what I would need to do. Cheers.
i think enuo posted up the dizzy wire swap ryan ? but a lot of his posts are edited tho iirc (ga info pool thread ?)
Can you not get nats taken out of ecu by ed? He can do it on k11s before 2000 on a dizzy inthink
