G'day guys,
Recently joined the forums because I've got a strange problem in my AUDM 1995 K11 that I got a few weeks ago as a learner car for my missus.
The first issue I was having was that it was shuddering on partial throttle and jerking badly when taking off... I think I've narrowed that down to the front lower engine mount being knackered (it seems like the engine is resting on the support when it's not loaded up)
The issue I have now, and the main issue with the car, is that the gearbox is playing silly buggers. It started out as an issue that seemed as though the gearbox forgot what ratio it was supposed to be in and it would randomly search for ratios. Then after a relatively hard drive one time, it seems to want to stick itself in a higher ratio (think: manual car in 4th gear), making starting from a stop next to impossible and getting up hills something I can no longer attempt at anything less than 80kph.
I don't feel like it's an issue with the clutch, because it seems to be trying pretty hard to get me rolling, despite the fact that the box is in some stupid ratio...
I did check the fluid in the box and it was a clear/brown kind of colour... which is wrong for the N-CVT (should be red)... So I replaced it with Penrite Semi-Synthetic ATF (a suitably priced replacement for Nissanmatic D) and it drove fine for a few minutes until it warmed up again then wanted to stick in the higher gear again.
This here, is the strangest part of this issue... The car seems to drive relatively normally when it's cold... It's only once the box/car warms up that the issue re-appears
Please someone help me... Not that I hate driving my MY06 WRX to work every day, but having a car that uses half the fuel is preferable for daily driving. That, and my missus needs a car to learn to drive in.
Appreciated in advance!
