Hi guys,
I need a little advice from fellow Micra owners. My Y reg k11 has developed a reeaallly annoying creaking sound from the front left suspension area and I'm wondering if you can help me diagnose it
Description:
- Creaking sound from front left suspension
- Is worse when only driver is in car, improves when carrying passengers.
- Creaks worse when doing a tight right turn (ie, pulling out from a side street or car park exit) and
when going over small bumps under normal driving (anything smaller than a speed bump)
- Handling does not seem to be affected, car drives straight and does not pull to a side, no
movement in steering wheel.
- Car does NOT creak if I bounce down on the bonnet (goes down when pressed and back up
once - no 'bouncy bouncy') It only creaks while driving. I can't get it to creak when its parked up.
- Car passed MOT in May last year, it had the creaking sound then as well. Nothing was mentioned.
- I've had a look around the area. Nothing obvious. No play in components.
In short, it's had this creaking sound for around a year. It steadily got worse until later in 2014, where it seems to have got to its worst. I don't want to spend £100's on garage fees for them to search for the problem as I can do most work at home in my garage, that's not a problem. What I want to know is if anyone has had this problem as well, and what it turned out to be?
Thanks in advance!
James
Description:
Thanks in advance!
James
