Hi all,
I have a K11, CG10 Micra that was running perfectly and then the other morning, crank but no start.
I have tested a couple of things but just wanted some info if anyone can help.
Snap-on Machine in the OBD2 port gave a P0340 Camshaft Position Sensor Problem Bank 1.
looking at live data i get 0 RPM reading when cranking.
If fuel is added to the Airbox / throttle body the car will start and idle and then die quite quickly.
I have tested the coils and im getting 12v to them on both the Green and Yellow Wires. and because it starts with fuel added im happy it has spark.
The injectors have 2 wires, both are getting 0.62 volts when cranking i would presume they need 5 or 12 volts to fire.
so, My main question is, would the cam sensor fault cause the injectors not to fire?
if so, everything is pointing to the faulty Cam sensor.
i have tested the wiring leading to the Cam sensor, and im getting 5 volts on the green/yellow with the ignition on, i am presuming this is the feed. The Black is Grounding fine, The white and green is 0.6v when cranking. im not sure if this is all okay or further points towards faulty Cam Sensor.
again would the cam sensor stop all injector function?
any help much appreciated.
Thanks.
Thanks.
