Made to fit are rare and very expensive, and ideally need strengthening done to rear shock mounts. Search for 'Official MSC K11 lowering guide', will give you some cheaper options.Hello Guys,
I am looking for a spare set coilovers fitting K11..
Some have some?
Kind regards
So what is involved In strengthening the mounts??
Why can't you use bc coilovers on road???
Hello Guys,
Some have some?
Kind regards
Polly you can change the stiffness without sacrificing ride height??
Quick way to a broken back
Suzie the Super S
not necessarily.
depends on how well it's setup to suit that vehicles mass, within the occupants acceptable ride comfort for a specific driving application.
these coilovers have alot of parameters to set and other optional spring rates to suit a need compared to other fixed solutions, just have to configure em correctly.
What coilovers do you have?Very true, but 9 times out of 10 people never really bother, which is a shame after all the development that goes into making them...
Suzie the Super S
I haven't seen sub £600 micra ones
Ah I see... well that's the same info either way thanksI dont, but looking into some FK coilovers at 360 pounds...
Suzie the Super S
Suzie the Super S
That's me out the picture then boys don't have the first inclin about coiloversexactly.
the full body coilovers are designed to provide users full control over various major suspension parameters to "fine tune/balance" it with the car and get closer to their target goal.
just like with any tool, they can be detrimental or even dangerous if the person doesn't know how to setup and utilise its full potential properly.
By all means get coilovers. Just stick to the 'default settings' as it were and use them to simply lower/raise the carThat's me out the picture then boys don't have the first inclin about coilovers
Depending what set you get they can have:
Damping rates (both bump and rebound)
Spring rates
Camber adjustment
Caster adjustment
Static chassis height
These can affect many things
Like centre of gravity balance, corner weighting, acceleration 'buck' and braking 'dive', body roll, weight transfer etcetc can go on hence why Paul said they can be dangerous if you dont know what your doing
The damping should be ok as they are designed to go that low that's all in the shock design.That's why cheap ones if you go mega low, the damping goes out the window because of how compressed the spring is when you lower it...
Suzie the Super S
You can JUST get away with no strengthening on the rear for rear coiloverd, assuming no corrosion whatsoever around the shock mount points. I'd recomend keeping the seperate shocks and springs and doi g corsa shocks and cut springs, but bristol roads are pretty brutal as Scott.C will confirm!. You'll needy an adjustable panhard rod whatever you do.
People remove the helper springs to go lower which leaves the main spring to do all the work. Over-compressing the main spring. In turn making it excessively stiff and skittish. I think that's what you mean?
