[K11] Clock DashBoard
Hi guys,
I have a k11 Super S and the dashboard clock does not work.
Someone can indicate which of the image bulbs is part of the watch?
you'll still be able to read the clock in day light even without the bulb so it its not visible there might be something else at fault. Might only illuminates then the side or main lights are on.... Failing that just check all the bulbs until you fins any that don't work :)
