K11 CG13DE raising compression
Hello Guys,
I've god new CAT Cams Camshafts. Those have a duration from 270 degrees and al valvelift of 7,98mm.
Now i want to raise my compression for a better powerband. What seems to be the best compression?
The stock compression from a CG13DE here is 9,5:1
What is the best way to raise that?
I've sorted out that my stock head gasket is 1,20mm thick. With this thickness i've got a compression from 9,5:1. If i place a steal head gasket from 0,5mm, what will that do to my original compression? how much wil it raise?
you wont gain much compression with a thinner gasket jeroen, mine,s had a 2mm headskim and it still needs more :eek: (260deg cams)
1.0 pistons are the best way to raise it really (and a headskim preferably)
Thanks for the reaction..
1.0 pistons will raise.. okay...
How much does the compression raise with only 1.0 pistons?
And what compression is ideale with 270 cams?
I want to use euro 95 petrol (octane 95 and no 98)
I'm very curious about how much horsepower it wil get...:laugh:
actually i got on better with this one jeroen
http://www.johnmaherracing.co.uk/enginecalc.htm
bore 71
stroke 80.5
deck height 0 (flush)
chamber + dish + gasket 37cc
C/R 9.6
and 1.0
bore 71
stroke 63
deck height 0
chamber + gasket 29cc
C/R 9.6
so the dish is 8cc
and if you enter the 0 dish (flat-top piston) to the 1.3 figures you get
bore 71
stroke 80.5
deck height 0
C/R 12:1 !!
Thanks a lot!
But don't you forget something?
the 1.0 AND the 1.3 have both a bore of 71..
If you place 1.0 pistons in a 1.3 engine, the stroke wil be the same.
Doesn't the 1.0 have a smaller chamber because his piston rods are longer?
I know that there is a difference between the piston rods from a 1.0 with a 1.3..
So maybe the dish isnt 8cc, but less because of the 1.3 piston rods..
the measurement from the pin to the crown is the same jeroen, so a 1.3 crank and rod with a 1.0 piston comes flush/level with the top of the block also (my 2 spare engines are 1.3,s with 1.0 pistons, pics in my blog)
attachment.php
so conclusion? it won't raise the compression?
I don't get your point.. Sorry for my misunderstanding
You say that the distance from pin to crown the same is..
So the difference is in rod that makes a different stroke.. what is the difference between the pistons that will raise comperssion/8cc?
no jeroen, the heights are the same (1.0 1.3) but the 1.0 (on the left) is flat-top and the others have a dish
attachment.php
ideally you would want 1 litre pistons, a 1mm headskim (or 39 thou depending on how 'good' your engineer is) and your thin gasket, that should give you a healthy cr.
Tnanks a lot Frank!
Now i know exactly what i'm going to do!
other pistons and 0,5mm gasket
bear in mind that the pins are an interferance fit in the rods tho jeroen (very very tight :eek:)
and where are you based ? and tell us more about your cams (pics ect)
Thanks Frank,
I am based in Holland. State: Overijssel, City: Zwolle..
My cams are made in Belgium of England, by CAT cams.
(Type 1601204)
Duration is 270 degrees, valve lift 7,98mm like i said.
overall, there is nothing more to say.. :p
I only need to build my 2" (52mm) exhaust system, fitting a Janspeed manifold and a cold air intake..
Other tings i am working at are brake discs at the back by fitting a rear axle from a german K11 with ABS, 100nx performance brakediscs at the front on rebuild brakes and a rollcage...
Just being busy ;)
Waiting for a GA16 to change everything ;)
