Hi folks I'm new to this site and I'm currently in possession of a 998cc engine and gearbox if anyone is interested. the engine is still in the car at the moment and can be heard running.The engine will come bare apart from the flywheel and clutch. The gearbox however won't come with the clutch release bearing arm/assembly as it is damaged where the clutch cable attaches, its a 2 minute job to swap the assembly from your own box over so it isn't really an issue. To remove the assembly you first remove the bearing arm (by this I mean the the part that the relese bearing is physically attached to) by removing the two pins connecting it to the rod with with a punch and a hammer. Once the arm is removed the rod will slide strait out the top of the gearbox
The engine and box are from a 1994 and have done 83845 miles from new. I was looking for around £70 for the bare engine and around £40 for the gearbox but I'm open to offers
