k11 cassette removal
Undid the surround, 2 screws where pull ashtray out, then thers 2 screws above the cassete head on the surround undo all them and the surround should come off, then you have acces to 4 surroundin screws the head unit which will then enable you to pull the cassete out
so once i have it out and have that cable its just a matter of plugging them in together, is there a right and wrong way of putting the cables together before i start, i see there's two black and one white on the iso lead
Dont need to do any wire chopping what so ever, mine just plugged straight in when i got the iso lead, itl only clip in one way so cant get it wrong,
are there wires already at the back of car to plug speakers into if you have a set, because that iso you mention says for only two speakers im a bit green on this topic
