Hi, first time poster & car DIY noob so try to go easy...
Need to replace one of the battery cables in my K11. The connector on the battery cable that sits on the negative terminal of the battery is worn down through oxidation & sanding and comes clean off the terminal when the engine is turned off. Need to get it replaced asap and would prefer to source the part and fit it myself.
Any suggestions re good online sites for sourcing micra battery cables or info re what cable type or spec I should be looking to buy and how to go about fitting it (preferrably safely )? Any help appreciated. Tks!
