Ah, do they? This sounds like the typical traction loss when a fwd car rolls over heavily on its rear outside wheel. Instead of identifying and fixing the real cause of the issue the 'crutch fix' is to give the car a fully independent front in an attempt to keep the front inside wheel on the ground. It's the easier cheaper solution too. Of course, in the same corner at the same speed, the car will dive into the turn then suffer further increased body roll, the outside front tyre will mispresent to the road, overload and slide earlier than before ultimately resulting in a slower corner, at least you wont have a smoking inside front tyre and no forward motion off he corner though.
Here is a graphic example of the difference. This car has a stripped interior, is lightened as far as f1000 rules will permit, has a lower gear ratio, has competition suspension and likely cost several thousand to build. His best option is to handbrake turn and spin wheels ie 'chuck it' round the course. Notice how the car virtually stops in every turn, listen to the engine note as it spins it's front inside wheel wasting time and tyres
Compare it's style to my car which is essentially stock but has lowering springs, uprated roll bars and therefore didn't
It is possible to go too hard the result is absence of weight transfer and loss of grip but the manufactureres don't make 'em that hard. IIRC my whitelines are some 250 times harder than stock! I was shocked to discover this at the time, yet I still obviously have bodyroll. The only serious downside of uprated roll bars comes when it comes to extremely low grip or extremely bumpy ground. Anti roll bars - missunderstood and vastly undervalued.
