Hi All, after much messing around I finally fitted the sunny Gti brakes I bought from a chap on here years ago. They needed 15mm spacers to clear the wheel with longer studs. My pressure bleeder did not fit the resevior so use the 2 man approach to bleeding. Not convinced they have bled correctly, I went round each brake in turn twice though, and the fluid was bubble free. I expected a bit more pedal travel with the slightly larger slave cylinder, but its really naff. Perhaps there is still some air in there but if not I'm really not impressed with this change and will probably go back to std discs.
Can anone else who has done the similar conversion comment on the pedal feel when using the std master cylinder? What load of effort for a long pedal.
Calipers- Sunny Gti
Discs and pads EBC, EBC green stuff.
Spacers Eibach pro 15mm per side.
rich
Calipers- Sunny Gti
rich
