C
Crazee
Hi Guys,
I hope some1 out there has encountered this little problem before cos all my mechies are completely stumped......
ok, so it started about 2 weeks ago i was quite happily driving along a very nice smooth road, approaching some traffic lights and as i backed off the accelerator the car hissed at me for a second... "wierd..." i thought, as i slowly put my foot back on the accelerator again as the lights ahead had changed to green it hissed at me again!
Now i can get the daft little micra to do this at will and very easily (but requires very little movement on the accelerator) , first heard in second gear approaching 15 mph, again in 3rd at around 22 mph, again in 4th at 30 mph and finally does it again in 5th at 40 mph.
I did find that one of the vacume pipes had come loose so i put it back and clamped it, this was the original diagnosis but didnt cure it. since then all the mechies at the car recovery company i work for have looked it over for where this noise is coming from but no-one can find it. I even went to the extreme and had all the vacume pipes replaced, just incase one of them had a small hole or split in it, but still no change.
The hissing noise doesnt seam to cause any other problems with the running of the car but is dammed annoying.
I hope I have given enough info for you guys, also hope someone has encountered this also.
Thanks in advance for any usefull info.
G
:k11motors
G
:k11motors
