Hi, my first post and ask for help! I've 99 1.0 Micra. It's a great little car, battered and bruised over the years (by others) but not without problems in the past. All sorted now, except for the new one yesterday!
All normal (starts straightaway, runs normal, all good), driving along until it gets up to temp., then shuts down.
Pump is fine (I start only after hearing it click, telling me it's up to pressure), battery good (have an old Berlingo battery, from a previous issue now solved), all standard warnings lights present at startup and after it shuts down. NATS was bypassed a while ago, replaced distro last year - no corrosion now, leads good.
So, as far as I can tell, something is failing at temperature - there's no spark, nor fuel (when I removed the plugs to check spark, I could not smell any fuel, and there should have been something in there are trying to restart). Checked fuses, all good. If I just wait, it'll run fine again, as if nothing was wrong. Six mins later (if just ticking over), shut down - just dies. Everything works, except fuel and spark.
After it orginally happened, my friend was having a look at a black box with looked like it has three relays (like fuses), and she started (as I was cranking it at the time). Now, it might have cooled by then, so I don't know if it's relevant.
Today, after leaving it overnight (after towing it back), she started as normal; after six mins, out like a light.
Hope someone can help, as I'm out in the sticks, a Nissan stealer is a long way away, and I'm new to the area (so no knowledge of a decent local mech). cheers
