Hi, I have a 2001 Nissan Micra 1.4L, active, it has 36000 miles on the clock, but has very bad idle when warm. When you start the car, and engine is cold, the car idles fine, as soon as the engine is at operating temperature the engine starts to idle very bad, it idles for 5 seconds fine and then its like the engine is about to die, then idles fine again, the only way I can explain this is very lumpy idle. I have replaced the complete throttle body and all 4 coils, the parts I used are in working order as I swapped them from a working car. Also I have replaced the spark plugs and fuel filter. The car has been stood for about 10 weeks, so tonight I am going to add some injector cleaner to the fuel and take it for a run.
Can anybody please help with what the problem can be with the car please.
thanks for your time
