So, picked up a complete car, T plate 1.3 non runner.
The girl I bought it from said it was running fine, came to start it again and it didn't want to know.
It cranks, its getting fuel, but there's no spark. Plugs get wet and you can smell it. Check the obvious stuff, dizzy is intact, rotor arm OK, leads OK, no burnt out fuses or links, everything else on the car works fine.
Tried to pull codes but I can't find the flashing led, removed the panel to reveal the ECU. Cant tell if I'm shorting the right diag pins, the Haynes manual isn't clear.
Amy pointers gratefully received.
Chris.
Chris.
