K11 1.3 Auto & Manual MAF ----------------
Hi guys, id like to know does the Micra K11 Auto 1.3 and the Manual 1.3 shares the same MAF or are there any difference??
Cheers Guys!!
J
Hi Guys thanks for your reply back, sorry i should have mentioned that the Throttlebody/MAF is from an M Reg (1995) car which is an Auto, and wanted to know definetly that if taken off the auto K11 (1995) would it be a straight swap over to my Manual K11 (1995) and work??? i havent seen the throttlebody yet !!!!
@mckenziecz you mentioned the MAF is the same but throttlebody is different is that for the later K11 facelift model?
Cheers again!!!
J
even the pre facelift, all i meant it that that is another cable from the throttle body going to the gearbox. you dont have to use it on manual car but you need it on auto, hope it make sence
