Hello everyone, first post here and I've found some really good infos around this forum but nothing that can really relate to my problem.
I've bought a 1997 K11 1.0l in december 2023 and it has always started great when cold but not when warm, I have to crank the key at least 2-3 times before it would start. I've read that it can be related to anything from the dizz cap, a cold solder joint in the throttle body or it's simply overfueling and I would need to fit a resistor in parallel to the engine temp sensor.
The car runs ok it doesn't cut off or anything. I've tried using a little bit of throttle when starting warm but it doesn't really make a difference so I would exclude the throttle body solder joint fix.
Does anyone have an advice on what to check first? Thank you very much
