Yeah the manifold does give some performance increase and yeah for the price you are better off seeing if you can get one made rather than modifying a k11 one which would probably end up costing the same or more. However, if you really want power try and get an inlet manifold made up too, as this can be quite restrictive, and both custom ones should see a fairly large increase in power. I have a 4-2-1 custom one on mine, which is just about identical to Marks and it does help compared to a standard manifold, just depends how much you wana spend really.
