16vFig
The continuing saga of dropping a CG13 into my wife's Figaro!
Having made the decision to go with the K10 5-speed box because the mounts and shifter hook up easier I finally found myself a K10 box, only to discover the gears are f***ed, and I mean properly f***ed. Several gear teeth came out with the oil.:down:
I've opened the box up and internally it looks the same(ish) to the CG11 5-speed box.
Does anyone know if the CG11 5-speed gears can be 'dropped into' a K10 5-speed casing?
Thanks!
Thanks!
