K Kyle Guest Aug 19, 2005 #1 When i go round corners the hand-brake light comes on, then goes off, when im out of the corner....anyone got any ideas what the problem is?
James Chairman Aug 19, 2005 #2 It means your brake fluid is low. Top it up with some DOT4 brake fluid Check after a couple of months that theres still plenty in as you may have a leak (this was the case with my K10). James.
OP OP K Kyle Guest Aug 19, 2005 #3 cheers mate worked a treat, just did a road test Is the DOT 4 stuff the same fluid for power steering or is it different stuff?
Arnold www.alanarnold.co.uk Moderator Site Supporter Aug 19, 2005 #4 CHECK YOUR BRAKE PADS The fluid drops when the pads are extremely worn, and the light comes on. When new pads are fitted, the fluid resumes to normal level. The fluid only really needs topping up if theres a leak
Arnold www.alanarnold.co.uk Moderator Site Supporter Aug 19, 2005 #7 I'd check the fronts. They take alot more grief than the rears
