K10 figaro conversion higher boost
Hi all i was wondering if anyone knows how I can raise my boost to about 10 psi and somehow remove the cut from the airflow meter the figaro stock boost is 6psi and want to put it up to 10psi can anyone help.
Yes, this is an issue. I found that I would get the cut when driving without the full factory intake (air box etc). I'm not sure if it is the air flow metre itself or the ECU cutting fuel at a certain point.
If it's the MAF, it may be possible to use a different air flow metre (S13 / Z32 ?) and / or use Nistune to modify the management.
