The back box on my K11 is very easy to change as the joint is just above the rear axle, however on the K10 the back box is joined onto a pipe that runs over the rear axle to halfway down the car to the joint. From memory you can only change the K10 back exhaust from either a ramp or pit and you need to jack up the car's body to get the height to pass the exhaust pipe over the rear axle.
Does anyone know if they do a similar exhaust for the K10 as the easier to fit K11 one?
Thanks for any information
Haybarn
Haybarn
