O
ohc_turbo
another quick question to clarify before i go down the scrappy and test it out.
It has been said that the k10 spider assembly fits into a GA inner joint so this does away with having total custom driveshafts.
if this is true this is good news as im thinking that when togeter the MA shafts will only have to be shortened to accomodate a larger GA gearbox.
ive never seen a K10 GA and dont know who has done one but have seen a K11 GA conversion, my way of thinking is if the other modification works out - the k11 hub on a k10 for larger brakes then the driveshafts are very similar.
a persons name who would know is quickdraw but he does not come on here anymore
there is other issues of using either primera shafts as donors or finding sunny n14 shafts either as 1.4 form or 1.6, looking on fast they are a similar setup between all models but the lengh of the shafts will vary between p10 and n14.
cheers for any ideas or help, im eager for more power, armed with a mig welder and a donor GA lump, it could be a fairly easy modification and would turn the K10 into a beast, there seems to be very little written up on this popular conversion
