Hi
After perusing these forums I bit the bullet and changed the water pump on my K10. I've never done a timing belt task before and was a little anxious but it went OK.
Now though I have developed a new leak - this time from the coolant pipe where it joins the engine under the dipstick. I believe this is just a "push fit" with an O ring. Is it likely that I dislodged the pipe when I allowed the engine to descend slightly after the RH mount was removed for the pump job?
Can I just disassemble and stuff back in?
Oh and that inaccessible nut on the mount... I confess I just had to leave it out for now. Just couldn't get any kind of a grip on that third nut!!!
Phil
Phil
