K10 Coil issue
You might have noticed my short k10 to k10 R ST build. Now that i have sold the MA09ERT-engine i decided to put it back together with the stock MA10 spiced with some superturbo parts like the LSD-tranny. but i ran into troubles with getting any spark, since i cant remember how the wiring went to Coil.. If any of you guys had a Pic or wiring diagram or just Wisdom to prep my micra for the winter seasons :D The Relay from keyswitch to coil is getting hot, so does the resistor next to coil, so something has gone wrong. Im also getting ground at the coil + pivot when grounding the - pivot!? If so, how could the coil be broken since i disassembled everything when it worked?
