Hi all,
I've got a 1988 1.0 GSX and unfortunately the rubber 'skirt' on the throttle spring inside has bust, has anyone got a spare carb I can buy or know of anywhere I can get one? If anyone has got an exploded diagram of the carburettor I would be interested in seeing it too, I've cleaned all the jets I can see but there's always that hidden one that nine times out of ten is causing the problem! It had a slight misfire occasionally on idle so I went to investigate and knackered it further, as you do...
Posting here as well as in the K10 section, I need the old girl back on the road ASAP
Many thanks,
Lew
Many thanks,
Lew
