K+n?
it depends mate! do you have a budget! do you have a "makers" preference as in you want a "k&n" over "pipercross etc" (which i think you do?)
on 1 you have a 90degree bend.....then a straight which is actually a good design!
the k&N sits on top of the TB but comes with cold air feed, but if your pland are to add a bonnet vent then maybe get this one? you can buy a straight later on etc??
i know i havent really help because induction kits are the hardest itmes to pick as the really all do the same
The TB is 70mm so get a silicon bend and stick some drainpipe on the end. I think drainpipe is 76mm so you need a silicon 90 degree reducer from 70 to 76mm. If you want I'll find one on ebay.
Can do, dont get paid till 1st feb mind ya
Im gonna get the non descript one then Il know it should fit no probs :)
