K&N panel filter
CMF_rocket
Not sure but i ran it on the standard box with some ducting all the way from the bottom front bumper to the air cleaner box and was pretty good, and gave a good sound but as for as good as pod not sure about that.
CMF_lam.666
i reckon its a good mod, as its not exposed to the heat coming from the engine, as it's enclosed in the airbox
if anything it'll be better than the stock air filter
CMF_rocket
It is very easy to install just replaced the factory air cleaner element, same size etc just Red washable material instead of paper element works well with some good intake as per other forums...thanks.
