Hi I'm new here just looking for other options on my fault any help would be gratefully received
Anyways my 96 p reg has developed a slight judder or even a slip as such when under heavy throttle ie if you boot it in second its hesitates like its not getting enough fuel or something, I've tries a few things and I've also done a few mods that may also be the culprit I'll list the mods and tried fixes
Mods:
Rev delete
Air induction pipe work and filter
Super 4 plugs
8mm performance leads
Replaced all air hoses for silicone due to old ones being perished
Fixes tried
New cap and rotor arm
Reflowed the throttle body
New leads and plugs
Could I be missing anything? Is it due too the induction as I've heard mixed results from inductions or could it be the rev delete confusing the ecu? I'm kinda at whim at the moment of were I should head next apart from getting a new throttle body and checking the ignition timing many thanks
Sent from my U7 Plus using Tapatalk
Mods:
Rev delete
Super 4 plugs
Fixes tried
New leads and plugs
